backfires
100,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
STEVE BOOK
truck backfires the PCV sometimes on starting, but
runs perfectly after resetting PCV cap.
Nov 18, 2016 at 2:48 AM
JIS001
  • 3,412 POSTS
Do you have the correct PCV valve installed? Also have you tried scanning for codes? I would use a more advance scanner for that rather then the quick small ones.
Nov 18, 2016 at 3:01 AM
STEVE BOOK
I have ordered the PCV valve. The only code that shows up is a knock sensor.
Nov 20, 2016 at 11:36 PM
JIS001
  • 3,412 POSTS
Okay, replace the valve and reset the light and let us know if that fixed the problem or if the code returns.
Nov 21, 2016 at 1:18 AM
STEVE BOOK
replaced the valve, the only code is a knock sensor, an if still backfired.
Nov 24, 2016 at 11:38 PM
  • 55,732 POSTS
Hey Steve,
I backfire could be caused by an leaking intake valve, here is a guide that will explain all reasons for a backfire.
https://www.2carpros.com/articles/engine-backfires-while-running
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Nov 26, 2016 at 11:14 AM
STEVE BOOK
does anyone know where the gulp valve is located on 1999 blazer?
Nov 30, 2016 at 4:40 AM
  • 55,732 POSTS
If your engine has one it will be near the exhaust manifold on either side.
Nov 30, 2016 at 12:28 PM
