engine backfires on startup
2001 GMC SIERRA
200,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
DON LOVE
it cranks but will not start, it will backfire. can you assist me with the reasons that will cause this problem?
i took out the EGR valve. i check the timing, the timing chain have some slack on it. do you think this is the problem?
Jun 17, 2020 at 8:39 AM
Good evening,
Yes, it can. The way to confirm it is to check the compression. If the compression is low, most likely the timing chain could be the issue.
https://www.2carpros.com/articles/engine-backfires-while-running
Jun 17, 2020 at 9:11 AM
DON LOVE
Okay, i will check for compression. thanks
Jun 17, 2020 at 9:49 AM
You are welcome.
Always glad to help.
Jun 17, 2020 at 10:04 AM
