Back window defogger and black rubber seals around all four doors
122,550 MILES • V6 • 2WD • AUTOMATIC
TEXASMOMMA627
I need the type of rear defogger that is glued to the inside of the rear window. On the right side of the defogger box are 2 attached wires and they are to be soldered to the 2 contact tabs that stick out from the right edge of the glass.
In my research I'm finding many different defogger's for the 2003 Chevrolet Impala LS, but they're different than the one that came on my car. I have the repair kit for the defogger, but can't find the right one for my back window.
I'm purposely staying away from the Chevrolet GM parts
because they're too expensive for me. I'm buying after-market parts and they're much more affordable. Can you tell me the name/part number for the specific defogger that'll work for my car?
Rubber seals: The rubber seals that are around each door leaks rainwater and all need to be replaced. On the outside of the doors and located right above the glass is a thin strip of black strip/seal? and needs to be replaced. Also, on the outside of the Windows is an angled piece of rubber that cleans the outside of the glass i.e. rain drops or condensation. This same angled piece of rubber is on the inside glass windows and clears off the inside condensation like the rubber window seal on the outside.
The trunk seal needs to be replaced too.
Sep 6, 2019 at 11:46 AM
MASTERWRENCH
  • 258 POSTS
It sounds like you simply need to glue the electrical connector tab back onto the defroster grid. There are two types of repair kits available. One to glue tabs onto the grid and another to repair damaged grid lines. You obviously need the one for the tabs. In most cases when the tabs break off, they can be removed from the connector and reused on the glass. If you no longer have the tabs, there is a copy called Frost Fighter who specializes in replacement parts specifically for window defogger systems. You can take a look at their website to find the specific tabs for your vehicle.
2CarPros. specializes in providing quality repair tips and and suggestions. Unfortunately we are unable provide part numbers for vehicle components. We leave that up to the professionals at your local auto parts stores and/or dealerships.
Sep 8, 2019 at 2:27 PM
