After being in an accident, the ABS light turned on, the alignment is off and the back wheel and bumper bent slightly upwards
197,000 MILES
CLIGHTSEY80
Someone ran into my back bumper and wheel. Now the wheel and tire appear to bend slightly upwards. I tried changing the wheel but that’s not it. Also, the ABS brake light came on and my alignment is off.
May 20, 2022 at 5:35 AM
SQM
  • 6,383 POSTS
Any time a vehicle has been in an accident, there could be a number of components that can get damaged/bent.
The ABS light can come on due to a bad sensor or a broken wire due to the impact etc.
A good step would be to scan and retrieve the ABS code(s), that can help with the diagnostics.
Here is a helpful video:
https://youtu.be/rTtAnsOlZU4
As for the alignment, it can be off for a number of reason as well. It could be due to any number of bent or damaged components.
The best option would be to try to get the vehicle aligned, that can tell you if there are major components that are bent or something that can be adjusted. It will all depend on the severity of the impact.
Let me know of any questions.
May 20, 2022 at 8:56 AM
