Back right brake is locked
35,000 MILES • 1.2L • 2WD • MANUAL
MCQUADEJ123
So the car is not able to move. I have tried reversing and going forward and also tried releasing and putting on the brakes a few times nothing has worked.
Feb 8, 2019 at 2:14 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
This usually means the rubber brake line that connects to the caliper has deteriorated/malfunctioned internally and will need replacing. After replacement you will need to bleed all four brakes. Here is a tutorial showing what is involved:
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Hope this helps and thanks for using 2CarPros.
Danny-
Feb 8, 2019 at 10:32 AM
