Back firing through exhaust
89,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
THEODORE SHAUGHNESSY
Under a load such as taking off from a stop or going uphill car back fires through the exhaust. I replaced plugs, wires, coil pack and coil pack module and exhaust from manifold back and I am afraid of blowing out the new exhaust which will void the warranty. still having the same problem. Any help would be greatly appreciated.
Feb 18, 2017 at 6:23 AM
  • 55,604 POSTS
Hi THEODORE,
It sounds like you may have a broken valve spring that is not returning the valve to the closed potion under load. Also I would do a fuel pressure test to make sure enough fuel is entering the engine. Here are a couple of guides that will give you more of idea what to look for and how to fix it.
https://www.2carpros.com/articles/engine-backfires-while-running
and
Please run some tests and get back to us so we can continue helping you.
Best, Ken
Feb 20, 2017 at 2:50 AM
