Backfire under loading going up hills in second and third gears?
305,000 MILES • 3.0L • V6 • 4WD • MANUAL
TOYOTA200010
My truck recently started back firing and rear end vibration/ hopping while going uphill at a steep grade. Only time it happens is put hill. Not on start nor flats or downhill. After warming up it idles around 500 RPMs when its set at 700. After driving for 5-10 minutes idle sits at 700 RPMs. Also smell of gas/oil on startup through heat/AC vents into the cab then goes away after 2-5 minutes.
Aug 1, 2023 at 10:12 AM
  • 55,694 POSTS
A backfire can be a misfire or lean fuel mixture. I would do a full tune up with the fuel filter replacement.
here are guides to help us fix the problem:
https://www.2carpros.com/articles/engine-backfires-while-running
and
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
Gap .................... 0.8 mm (0.031 in)
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem so we can see what's going on.
Aug 2, 2023 at 12:00 PM
