Back fire, sputter, surging, dies at any speed, just shuts off.
1998 JEEP GRAND CHEROKEE
201,000 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
CLIFTONLEWIS1983
One day it will drive just fine. Next it will sputter and surge. Then drive thru town at lights it will die if not on the gas/ sometimes. Then chugs and surges going down the rd at 30mph. Some times it just stops having problems for a couple days. Just runs great. (Alt, plugs, wires,battery, cap, rotor, gas cap, water pump, valve cover gasket, all new, installed by trusted wrench.)
Sep 8, 2016 at 1:45 PM
HMAC300
  • 48,601 POSTS
scan for codes and check fuel pressure with a gauge auto parts rent it.
also clean throttle plate on bothsides and iac hole with choke cleaner.
Sep 8, 2016 at 11:32 PM
