B2292 Restraint System Safety Belt Pretensioner Status?
2006 LINCOLN TOWN CAR
80,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
STRICTLYDIMES
  • 29 POSTS
Got this code on my car listed above. Which seat belt side is it and is it the button side or the retractor side? Or is it the middle seat belt? Thanks in advance.
Jul 2, 2025 at 8:25 AM
STEVE W.
  • 15,348 POSTS
Pretensioner would be in the retractor side. Sort of a mini airbag charge or heavy spring that pulls the belt tight in the event of an impact. Unfortunately, this code is set for any of them in that car as it fires both of them and only the passenger classification sensor determines if the passenger side actually goes off. So if you have a passenger, it sets off both, if not only the driver's side trips, but both are monitored with the same circuit and set the same code. So, a simple test like unplugging the passenger side, won't set a different code than unplugging the driver's side. Instead, you need a scan tool and the correct diagnostic load to test the system and determine which side is the problem. The tools are part number 418-F088 and are special diagnostic loads used to test the system. Basically, you disconnect one side, plug in the tool, then erase the code and see if it returns on the restart. If it does, you try the other side. and if it doesn't return you replace that belt retractor. (Won't be the middle belt. It doesn't have one in it) There are other tests for resistance and power but most of the time the scan tool and the loads will show the problem. Do not attempt to test the resistance of the pretensioner, the voltage from some meters can set them off!
Jul 2, 2025 at 1:01 PM
STRICTLYDIMES
  • 29 POSTS
Thanks for the reply.
Two questions:
1) does this tool 418-f088 you referenced need a special type of scanner, ( or can I just buy the pig tails itself) if not, which scanner is needed?
2) my air bag light flashes three times for a total of six repetitions. Then it stays on constantly. Occasionally i will hear a beep 5 times in a row for a while with still having light on constantly.
Thanks in advance for your advice.
Jul 4, 2025 at 5:37 PM
STEVE W.
  • 15,348 POSTS
The light and beeping are to tell you there is a fault in the system related to the retractors and the light staying on tells you the air bag system is disabled because of it.
They can be used with any brand of scan tool, but the tool itself has to be one that can read the live data from the SRS system and can run the tests needed to see the actual errors and resistance change without setting off the system.
Jul 4, 2025 at 5:42 PM
