Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ranger
Electrical
BCM
Codes
B1359
B1359 code?
2003 FORD RANGER
99,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
DARIN EMMETT
MEMBER
Hello I'm looking for the ignition switch wiring diagram to troubleshoot the b1359 code.
Jul 28, 2025 at 1:44 PM
Experienced Mechanic
Yep, good call, it looks like the switch is bad.
B1359 - Ignition Run/Accessory Circuit Failure
Here is how to change the switch out and the wiring diagrams as requested. Check out the images (below). Let us know if you need anything else.
Images (Click to enlarge)
Jul 29, 2025 at 4:37 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
