B121715?
140,000 MILES • AUTOMATIC • ELECTRIC
STEFAN KELLER
Light left error but Bulp and fuse ok
Oct 1, 2026 at 11:10 AM
STEFAN KELLER
Head Light front left not working even with bulb and fuse ok
Oct 1, 2026 at 5:12 PM (Merged)
MECHTRIX
  • 583 POSTS
Ok that code indicates a problem in the low bean circuit specifically so
it one of 3 things
1..the ecu cut off the power to the circuit when the bulb or fuze blew and cast a code most time to ecu will restore it back to its factory setting only after erasing the code ..(most comon)
2 ..one of the 2 wore in the circuit cold be touching power somwhere or power could have e sounded out
3..the plug or wire is broken corrided disconnected...
My honest opinion is its door number 1 (most likly ) just erase the codes and see what happens let us know what you find
Good luck hope this helps
  • 55,694 POSTS
B121715 indicates a left low-beam headlamp circuit fault—an open circuit or short to battery positive. It doesn’t necessarily mean the bulb is bad.
Oct 1, 2026 at 6:34 PM
