Axle wheel hub nut size?
2,000,000 MILES • 3.9L • 6 CYL • 2WD • AUTOMATIC
CODYWATSON
What size socket to use on the vehicle listed above front axle wheel hub nut?
Feb 21, 2024 at 1:37 AM
  • 110,248 POSTS
That isn't something that is in our manuals. However, from memory, it is likely around 32mm. Do you have a set of hub nut bolt sockets?
Feb 21, 2024 at 11:59 AM
