what size is the wheel bearing nut?
150,000 MILES • 3.4L • 6 CYL • 2WD • AUTOMATIC
JOHN9454
I would please just like to know what size the axle nut,or wheel bearing, hub assembly nut is? And is it a deep well? And would a 6 point socket be recommended. Thank you. Also, sorry, what is the torque on this nut so when I put it back on? Thank's again .
Feb 17, 2018 at 8:14 AM
HARRY P
  • 2,292 POSTS
36mm. I would suggest a 6 point socket for it because they are less likely to strip the nut. You are going to be putting a lot of torque on it and need as much grip as possible. 159 ft lbs torque. I doubt they come in more than one depth. They sell the sockets at AutoZone for approx $10.00.
Feb 17, 2018 at 11:03 AM
JOHN9454
Thank you very much!
Feb 17, 2018 at 9:26 PM
