Axle bearing I think
156,000 MILES • 6 CYL • AUTOMATIC
TRACYG74
I was in an accident hit from the back could that have caused something to happen to the axle because now it is leaking oil?
Mar 19, 2016 at 10:04 PM
  • 31,937 POSTS
You may have to send in a picture of the affected area it may be a split case, pinion seal, axle seal, so a picture will be a big help.
Mar 20, 2016 at 2:05 AM
TRACYG74
I can't get a photo of it but was I told it was my axle and it was leaking major oil.
Mar 20, 2016 at 2:22 AM
  • 31,937 POSTS
If it is the axle seal, the axle will have to be removed to replace the bearing and seal, if the car was hit here, it may be bent as well and that will have to be investigated as well, if it is bent or the housing is damaged it will fail again sooner rather than later.
Mar 20, 2016 at 1:31 PM
TRACYG74
Thank you!! Have an awesome Sunday
Mar 20, 2016 at 2:00 PM
  • 31,937 POSTS
how did you get on with this problem?
Mar 22, 2016 at 6:42 AM
