AWD to FWD swap
115,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
DAN FLORES
Can I swap out an AWD and put in a 2wd transmission?
Jul 17, 2020 at 8:24 AM
Good evening,
Yes, you can but you will have to have the PCM reprogrammed to a front wheel drive. If you do not, then you will end up with a lot of codes in the system.
Why do you want to do this swap? Is there an issue with the rear differential?
Jul 17, 2020 at 9:29 AM
DAN FLORES
Just hard to find AWD transmission. found out that 2wd are less expensive (half the price).
Jul 17, 2020 at 10:43 PM
DAN FLORES
How hard would it be to reprogram PCM?
Jul 17, 2020 at 10:46 PM
Okay, can I have the VIN number so I can see if I can get or locate a transmission for you?
https://www.2carpros.com/articles/transmission-replacement-removal-manual
The dealer would have to perform the programming. This is not something you can do.
Jul 17, 2020 at 10:52 PM
