All wheel drive not working
130,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
BRIAN CAMPBELL2
My AWD is not working.
Feb 1, 2018 at 12:46 AM
  • 55,711 POSTS
This can be because you have a wheel speed sensor that is out. Can you follow this video to scan the ABS this will tell us whats going on?
https://youtu.be/rTtAnsOlZU4
Please let us know what you find.
Cheers, Ken
Feb 2, 2018 at 5:32 AM
BRIAN CAMPBELL2
Hi, I do not have an AWD code showing on the scanner. Also, I do not have a check engine light on.
Feb 2, 2018 at 6:53 AM
  • 55,711 POSTS
Even though the light is not on it may still have codes. This will be an ABS system scan which works the traction control/AWD. You can get a scanner for about $110.00 on Amazon.
Feb 3, 2018 at 2:08 AM
BRIAN CAMPBELL2
Ken you are not understanding what I am saying, I have a scanner that reads ABS. It is not showing a code.
Feb 3, 2018 at 7:10 AM
  • 55,711 POSTS
Okay, sorry lets try a different approach. Here is the wiring diagram for the all wheel drive unit so we can see how it works. There are three fuses I would check first # 8, 49 and 22 here is a guide to help us check the fuses.
Here are the fuse panel locations and identification.
If the fuses check out I would see if the encoder motor is getting power and if so I would replace the encoder.
Check out the diagrams (below).
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Feb 4, 2018 at 3:28 AM
