Title: 2008 Avenger 2.4L — No crank, PRNDL dark, new TIPM + PCM, Park bypass didn't work
2008 Dodge Avenger 2.4L. No-start for 18 months. I'm doing this myself, solo, no money for a shop — need zero-cost tests first.
Current problem: Turn the key, dash lights come on, no crank, no click, no start. PRNDL display is dark. Jumping the starter at the TIPM turns the engine over but it doesn't catch.
What started it: Car used to start, idle about 5 seconds, then die, even holding the gas down.
Already replaced: throttle body, battery, fuel pump, injectors, coil packs, spark plugs, intake gaskets, MAP / cam / crank sensors, both VVT sensors, TIPM, PCM (programmed to my VIN, same part number), shifter assembly, ignition switch, water pump, thermostat housing, upstream O2 sensor, intake manifold runner valve, airflow sensor, transmission solenoid pack / fluid / filter, manual lever bushing, fuses and relays. All fuses and relays are good.
Already tested / ruled out:
- A mobile tech with a scan tool said the TIPM was working and everything under the hood was working — the PCM was the only thing he couldn't get to on his scanner. New VIN-programmed PCM installed after that, still no crank, no start.
- My OBD reader connects, no codes. P0562 (voltage low) cleared and stayed cleared. The reader's VIN function shows no numbers — it just scrolls across.
- Battery healthy, 12.56V at battery and under-hood post. TIPM power restored after cleaning the battery-to-TIPM cable — 12.78V at the TIPM stud. Fuse 31 (starter) lights in RUN and START.
- Transmission pack range sensor ruled out — tested two different packs, same all-open readings and same dark PRNDL / no crank.
- Tried tying the TRS sense wires to ground at the green external harness connector to fake Park — still no P on the dash, still no crank.
- PCM connectors checked Nov 13 — tight and fully seated.
- CAN C pair (white/light blue and white/light green) photographed Nov 20 — twist pattern is factory: not twisted right at the PCM connector, twisted along the run, separates where it branches. Not tampered with.
- Aftermarket wiring ruled out as dead ends: a red power wire and a braided wire were both cut off in the trunk, not connected to anything. Loose white multi-pin connector under the dash with no mate.
New find (Nov 20): I found a hand-twisted splice with exposed copper and melted insulation in the gray connector under the TIPM, at the bottom among the big green/gray connectors. I identified it as connector C10, yellow/orange wire, transmission control output. It's a single wire. I spliced it back together with heat shrink, also replaced a pink wire and a faded over-bent wire that looked like it might break, wrapped everything up and reassembled. Still no start, PRNDL still dark — but the shifter now works without the override and the key comes out easily, which it didn't before.
Question: What should I check next that I haven't already? What would cause a dark PRNDL and no crank with a new TIPM and PCM, with good battery at TIPM and no codes?
Nov 21, 2026 at 11:43 AM
