Not starting but there is power
2004 CHEVROLET AVALANCHE
160,000 MILES • 5.3L • V8 • 2WD • AUTOMATIC
GILFG
My truck was running perfectly and I took off the battery to put it on another car (battery is good) and put it back and everything turns on except the engine just makes a clacking sound every time I turn the key.
Oct 19, 2019 at 2:42 PM
  • 110,194 POSTS
Welcome to 2CarPros.
When you turn the key to start, is it a click? Are you sure the battery terminals are clean and tight? Is it possible for you to record the sound so I can hear it?
Since it was find and since the battery was removed, I suspect it is a connection issue. Take a look through this link.
I realize you didn't mention all the lights go out, but based on your description, this is where we need to start. I suspect it is a connection issue.
Oct 19, 2019 at 8:42 PM
GILFG
Thanks. I found the problem; my battery has two types of terminals and the ground burnt out. so I switched the negative wire to the other negative terminal and got it running.
Oct 20, 2019 at 12:12 PM
  • 110,194 POSTS
Welcome back:
You are very welcome. I'm glad you found the issue. I had a feeling it dealt with a connection problem. Regardless, you got it going.
Take care and let us know if you have questions in the future.
Oct 20, 2019 at 9:33 PM
