Auxiliary battery malfunction
100 MILES • 3.5L • V6 • 4WD • AUTOMATIC
DTRAIN46
  • 8 POSTS
I've changed the alternator twice and charge the battery to the full capacity and the auxiliary battery light still comes on.
Aug 12, 2019 at 5:23 AM
BMDOUBLE
  • 1,139 POSTS
You will need to replace the auxiliary battery located in the trunk area. I've attached pictures with instructions.
Aug 12, 2019 at 5:46 AM
DTRAIN46
  • 8 POSTS
I have check the trunk, but it's not in there.
Aug 12, 2019 at 6:00 AM
BMDOUBLE
  • 1,139 POSTS
Then yours may be mounted in the dash on the driver’s side. It’s the size of a power wheels battery, super small. The panel at the driver side knee area and the small panel on the left side of the dash accessible when you open the door, pop the panel out and remove the 10mm bolt and the battery will drop down so you can grab it from below the dash. Some E classes have it in the trunk area and some on the driver side dash area.
Aug 12, 2019 at 10:19 AM
JIS001
  • 3,412 POSTS
Hello, just wanted to jump in as well. As BMDOUBLE stated earlier, the auxiliary battery should be in the luggage compartment. Mercedes gives a poor diagram as to the exact location but it looks like you will need to remove the trim covers to actually see it?
I would recommend you get an advance scan tool and do a full system scan to see what codes may be posted. Once you have those codes we can further assist. Also when I mention a scan, I do not mean those quick scans you get from the parts stores. You only get engine and maybe ABS codes. I am talking about a full scan where it scans every module in your vehicle.
Let us know if you find the auxiliary battery after removing all panels in trunk or if you can get the whole computer system scanned.
Aug 12, 2019 at 4:06 PM
DTRAIN46
  • 8 POSTS
Yea, I looked it up and it looks like it might be under the driver side dash.
Aug 13, 2019 at 9:26 AM
DTRAIN46
  • 8 POSTS
It's a 2010 e350 4matic.
DTRAIN46
  • 8 POSTS
Does it have to be a Mercedes battery? Because they have them at battery's plus but the are Duracell.
Aug 13, 2019 at 9:39 AM
BMDOUBLE
  • 1,139 POSTS
As long as it’s the same physical size and volts, it will work.
Aug 14, 2019 at 1:35 AM
DTRAIN46
  • 8 POSTS
Okay, it's a little smaller and more volts. Is that okay?
Aug 14, 2019 at 6:37 AM
BMDOUBLE
  • 1,139 POSTS
Volts or amp hours? it needs to be 12 volts.
Aug 15, 2019 at 3:03 AM
DTRAIN46
  • 8 POSTS
Is it okay to drive it until get the battery?
Aug 16, 2019 at 7:44 AM
BMDOUBLE
  • 1,139 POSTS
Yes you can still drive it.
Aug 16, 2019 at 8:18 AM
DTRAIN46
  • 8 POSTS
Good, because I haven't driven it for weeks now. tired of driving my truck. just got to get that battery now.. thanks
Aug 16, 2019 at 9:28 AM
BMDOUBLE
  • 1,139 POSTS
Roger that!
Aug 16, 2019 at 1:50 PM
ELSAGEORGE
I was facing the same issue and came across this blog, it also helped me a lot to identify where auxiliary battery is located and how to install it.
https://xenons4u.co.uk/blog/mercedes-benz-auxiliary-battery-malfunction-explained/
Sep 15, 2019 at 9:35 PM
