Hi, I recently purchased this car which already had some minor problems with the gears which gradually became more...after filling the almost empty transmission fluid I found that the oil seal on the drive shaft was gone and losing all the transmission fluid from their .I'm waiting for the seal at the moment ..the transmission shudders in drive and first gear ..and I use second to take off .when cold it jumps with a cluck sound into drive and goes okay when warm I take off with second and no problem with 3 and 4 gear up or down .it only takes 20 meters for second gear to lock in but after that everything is okay sometimes the automatic gear fault goes on .and when it is a hot day in traffic my engine goes very week as if it's working with 3 pistons ..I have not taking it to mechanic yet to see computer .and was thinking of changing solenoids. also do you think it is too late to fix it ?? Or can the problems be fixed ?? Please help me.
Dec 26, 2019 at 2:34 PM
