Automatic transmission issue
50,000 MILES • 3.5L • 6 CYL • 4WD • AUTOMATIC
ALIALBIR2
I noticed that when I am using my car's automatic transmission on D position it is sticking on fourth then fifth without starting from first, second and third. Whereas on S manual position, I can control from first to fifth.
Thanks
Feb 19, 2018 at 9:11 PM
Good morning.
I would start by changing the oil/filter in the transmission. It sounds like a valve body issue from some debris in the passages.
Are there any codes stored in the system?
Feb 20, 2018 at 12:08 AM
