Automatic transmission fluid filling port location
113,210 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
JERRYCRUDO1
Where to locate the filling portion of an automatic transmission fluid, cannot find it?
Jan 2, 2018 at 6:09 PM
  • 55,743 POSTS
Here is a guide to help you get an idea of how to check the transmission fluid in your car.
Here is what the book says
AUTOMATIC TRANSAXLE FLUID
INSPECTION
Drive the vehicle until the fluid reaches normal operating temperature [70-80°C ].
Place the vehicle on a level surface.
Move the selector lever through all gear positions. This will fill the torque converter and the hydraulic system with fluid and move the selector lever to the "N" (Neutral) or "P"(Park) position.
Before removing the oil level gauge, wipe all contaminants from around the oil level gauge. Then take out the oil level gauge and check the condition of the fluid.
NOTE: If the fluid smells as if it is burning, it means that the fluid has been contaminated by fine particles from the bushes and friction materials, a transaxle overhaul may be necessary.
Check that the fluid level is at the HOT mark on the oil level gauge. If the fluid level is low, add automatic transaxle fluid until the level reaches the "HOT" mark. Auto transaxle fluid: DIAMOND ATF SP-III, SK ATF SP-III
Quantity: 10.7 l (Diesel), 10.9 l (Gasoline)
NOTE: Low fluid level can cause a variety of a abnormal conditions because it allows the pump to take in air along with fluid. Air trapped in the hydraulic system forms bubbles, which are compressable. Therefore, pressures will be erratic, causing delayed shifting, slipping clutches and brakes, etc. Improper filling can also raise fluid level too high. When the transaxle has too much fluid, gears churn up foam and cause the same conditions which occur with low fluid level, resulting in accelerated deterioration of automatic transaxle fluid. In either case, air bubbles can cause overheating, and fluid oxidation, which can interfere with normal valve, clutch, and brake operation. Foaming can also result in fluid escaping from the transaxle vent where it may be mistaken for a leak.
Insert the oil level gauge securely.
NOTE: When new, automatic transmission fluid should be red. The red dye is added so the assembly plant can identify it as transmission fluid and distinguish it from engine oil or antifreeze. The red dye, which is not an indicator of fluid quality, is not permanent. As the vehicle is driven the transmission fluid will begin to look darker. The color may eventually appear light brown.
Let us know what happens and please upload pictures or videos of the problem.
Cheers, Ken
Jan 4, 2018 at 6:44 AM
