Can i use Valvoline Import full synthetic automatic transmission fluid in my vehicle listed above?
Jan 6, 2025 at 1:07 PM
STEVE W.
✓Experienced Mechanic
Your Santa Fe uses Hyundai 00232-19057 SP4-M transmission fluid if it is the conventional automatic. Looking at the compatibility on their bottle it only lists the SP-3 so I wouldn't use it.
Jan 6, 2025 at 2:46 PM
JOE1953
MEMBER
Where do I buy the 00232-19057 SP4-M transmission fluid from and how much it cost?
Jan 6, 2025 at 7:25 PM
STEVE W.
You can get the OEM fluid from a dealer or look around for fluid that says it is SP-IV M compatible. There are a couple companies that have it, many parts stores can also get it if they don't have an equivalent in stock.
how do I know if the fluid is bad? The fluid I drain out the color of it is a dark color.
Jan 13, 2025 at 6:02 AM
(Merged)
Transmission fluid should be a translucent red color. If it is dark, chances are it is dirty or burnt. If that is the case, I would recommend servicing it.
Take a look through this link and let me know if it helps:
