When shifting into reverse sometimes it grinds
200,000 MILES • 4 CYL • FWD • AUTOMATIC
WILLIAM MARTINSON
Sometimes when I shift into reverse it grinds like the park pin is stuck and will not engage into reverse. if I move the shifter back and forth it will backup just fine. I adjusted the shifter cable, but did not change anything. a local transmission shop says the shifter fork is worn out and to pull a cover off the end of the transmission and change it out. does anyone know if this is possible?
Dec 5, 2016 at 3:14 AM
  • 55,746 POSTS
Hey WILLIAM,
Yes in these transmission the shifter fork can wear not allowing the transmission is fully go into gears.
Please let us know happens so it will help others.
Best, Ken
Dec 10, 2016 at 4:36 AM
