Transmission has a huge thump and the engine warning light comes on with the overdrive light flashing. it takes very long to change gears.
Mar 7, 2018 at 4:49 AM
✓Experienced Mechanic
check oil level and i will need a code from the engine and transmission to get an idea as to what is going on here.
Mar 9, 2018 at 8:53 AM
LUTFIEM
MEMBER
P0016 Crankshaft position-Camshaft position Correlation.Transmission fluid was low.But the thumping noise in the transmission only comes days in between.
Mar 11, 2018 at 11:02 PM
You will need to get a line pressure Test done, the thumping my be a sticking Servo you may have low line pressure which can be caused by a blocked filter
Mar 12, 2018 at 7:39 AM
LUTFIEM
MEMBER
Thanks but what is this P0016 code?
Mar 12, 2018 at 3:42 PM
P0016
Timing chain stretched, or timing belt skipped a tooth due to wear
Misalignment of timing belt or chain
Faulty crank shaft position sensor
Faulty camshaft position sensor
Damaged wiring to crank or cam sensor
Timing belt or chain tensioner damaged
Mar 12, 2018 at 6:47 PM
LUTFIEM
MEMBER
Thank you so much .This has been extremely helpful.
Mar 12, 2018 at 6:51 PM
ok, look into these problem and if you need further assistance please re post.
Mar 12, 2018 at 7:03 PM
LUTFIEM
MEMBER
Thank you so very much for your information .I replaced the timing chain and tensioner.I also topped up the automatic transmission .Car drives like a dream now.Once again much gratitude .
Mar 20, 2018 at 4:41 PM
That's great news! Thank you for using 2carpros, please tell your friends about our service.
