Automatic transmission shifts fine when cold?
230,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
HOTSHOT20000000
Shifts fine when cold when in operating temp it fails to shift at all. Ive already cleaned the shift solenoids
Mar 31, 2026 at 7:11 AM
  • 55,766 POSTS
So this happens when the transmission is worn out, can I ask if the fluid smells burnt? You can try changing the fluid out but most of the time when the fluid is burnt the transmission is toast. Please upload a short video in your response of the fluid, so I can see what's going on for sure.
Apr 1, 2026 at 2:32 AM
