Shifts fine when cold when in operating temp it fails to shift at all. Ive already cleaned the shift solenoids
Mar 31, 2026 at 7:11 AM
✓Experienced Mechanic
So this happens when the transmission is worn out, can I ask if the fluid smells burnt? You can try changing the fluid out but most of the time when the fluid is burnt the transmission is toast. Please upload a short video in your response of the fluid, so I can see what's going on for sure.
