Automatic transmission stops working after about twenty minutes, codes P1298 and P1410
180,000 MILES • 4 CYL • 2WD • AUTOMATIC
MRKRETZER
Works fine for about 20 minutes. Then the transmission goes completely out. No gear works and engine revs. I changed fluid multiple times and then put in a new TCC solenoid, but it didn't help. No transmission codes come up but P1298 and P141 do come up. I don't see how either of those could have anything to do with the problem.
Feb 2, 2020 at 4:24 AM
TOUGHDIVER
  • 226 POSTS
Unhook your battery terminal for 10 minutes to reset the ECM. Every sensor and electrical circuit has something in common with the power-train. Let us know if this was helpful or you need more information. I'm attaching repair guides below for you to refer to.
https://www.2carpros.com/trouble_codes/obd2
Thank you
Joe T.
Feb 2, 2020 at 10:24 AM
MRKRETZER
The battery was unhooked for more than 10 minutes while I changed the solenoid. Do I need to do it again?
Feb 3, 2020 at 12:58 AM
TOUGHDIVER
  • 226 POSTS
Yes do it again. it may have set an error when you were road testing it.
Feb 3, 2020 at 3:55 AM
  • 55,658 POSTS
Does this car have the CVT transmission? Also is it a hybrid?
Feb 3, 2020 at 9:31 AM
MRKRETZER
No, not a CVT and not a hybrid.
Feb 4, 2020 at 12:03 AM
  • 55,658 POSTS
P1298 is for the electrical load sensor which can be the alternator or battery going out how does the engine turn over? lets test the battery. here is guide to help us.:
P1410 EGR Valve Position Sensor Circuit Malfunction so I don't think that is it, I would try the input speed sensor which had big problem with them. here is video to show you how:
https://youtu.be/f3bETtCIdxM
Feb 4, 2020 at 7:15 AM
