Automatic trans Not moving while in gear/ grinding noise
200,000 MILES
RALVES912
Just purchase this car thinking it needed a new transmission but then told may be another problem. Car turned on and doesn't make any noise while in park then When shifting into any gear the car will not move and makes a grinding noise even when I put back into park.have Ti shut car off and restart for noise to stop
Sep 2, 2013 at 5:08 AM
HMAC300
  • 48,601 POSTS
have a trans guy check it it may be a bad converter or pump
Sep 2, 2013 at 5:45 AM
RALVES912
Thank you. What type of converter? Do you know?
Sep 3, 2013 at 4:28 AM
HMAC300
  • 48,601 POSTS
that would be the torque converter that is with 99.7% of all automatic trans missions.
Sep 3, 2013 at 5:02 AM
