Automatic temperature control
236,000 MILES • 3.2L • 2WD • AUTOMATIC
SPYDERMAN65
Installed a new ATC module. It works on startup for about ten minutes and then display goes out but heat still works, just cannot control or adjust it.
Jan 30, 2018 at 2:54 AM
  • 55,748 POSTS
That unit needs to be programmed into the system or you have a defective unit. Does the old one work or work as it did?
Let us know.
Cheers, Ken
Jan 31, 2018 at 6:30 AM
SPYDERMAN65
The old one had no display, but the heat still worked I just could not control it.
Jan 31, 2018 at 6:45 AM
Did you verify connection at the back of the A/C unit? check the connectors for any damage or loose pins. bad connections are common for this issue.
Jan 31, 2018 at 3:03 PM
