Transmission does not shift into fourth gear?
267,457 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
TRAVISCOHOON1
my car shift through the first 3 gears fine but wont shift into 4th.
Mar 5, 2021 at 3:05 PM
More then likely this is the torque converter clutch solenoid or the converter itself has failed.
We need to start with checking for codes and go from there.
Once we know if there are codes or not we can go in that direction. If there are no codes then we need to follow the testing information below to try and confirm the converter is the issue. However, this is what I suspect the issue is.
Let me know if you have questions. Thanks
Mar 6, 2021 at 10:35 AM
