Transmission issues
170,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
GEORGE RAYMOND WYSOSKI JR.
only movement when in reverse until operating temperature then nothing. forward movement sometimes in D-1, until warm then nothing at all no other forward gears no matter the temperature can you help? Please and Thank you if you can.
May 24, 2017 at 7:59 AM
  • 55,770 POSTS
First check the fluid level to see where you are at. Then please scan the computer for codes to see if you have a turbine or shaft speed sensor that has gone out.
Here is a guide to help you get started.
Please run this test and get back to us so we can continue helping you.
Cheers, Ken
May 26, 2017 at 9:10 AM
