Automatic door locks draining battery
138,770 MILES • V6 • 4WD • AUTOMATIC
TGIRARD
Is there a fuse for door locks? My battery is being drained by auto door locks. When I get my vehicle started the locks start locking and unlocking over and over so after I stop driving and turn off engine the locks locks and unlock until the battery drains. So can I pull a fuse and unlock and lock manually? Just until I can get repaired?
Mar 14, 2019 at 2:27 AM
  • 110,248 POSTS
To power down the locks, you have to remove fuse 10 which is a 10 amp fuse. It is located at the end of the dash (left side). Now the problem. This fuse provides power to the body control module and will shut other things down too, so check to make sure what works and doesn't work prior to driving.
Mar 15, 2019 at 1:27 PM
