automatic changing
185,689 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
GENO49
Removed MAP sensor wiring while still running, heard a pressure collapse sound, put wiring connector back on, looked at dash, engine light on, stayed on for a while, then eventually went off. that is when i started having gear delayed problems, would not change at drive to go forward unless i brought the speed up a little with the accelerator, once moving going okay.
Oct 2, 2019 at 1:17 PM
  • 55,721 POSTS
Lets clear the codes to see if the computer comes back online. Here is a video to help us:
https://youtu.be/ahK_eucFi-k
Can you please shoot a quick video with your phone so we can see what's going on, that would be great. You can upload it here with your response. Please run down this guide and report back.
Oct 4, 2019 at 6:47 AM
