Transmission not engaging, codes 0700, 0730, 0740
180,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
BSATTERW
Transmission works fine hot or cold for thirty seconds or so all gears and reverse. Then it is like its in neutral.
Turn it off, let it sit for one or two minutes, runs fine all gears then it is like its in neutral.
Fluid looks fine and does not smell burnt.
Shift linkage looks fine at transmission.
Codes are 0700, 0730, 0740.
Tested resistance all exterior solenoids they meet specs.
Applies voltage to each they click.
Removed each checked screens and spool movement they check okay.
Fluid level okay.
Temperature sensor works fine compared to temperature gauge.
Checked all solenoid connection seem okay.
Each time i start it it works okay for thirty seconds to a minute then it is like it is in neutral all gears.
Jan 21, 2019 at 1:30 AM
  • 110,248 POSTS
Interestingly, I checked each code and the diagnostic flow charts. The 700 is generic and non specific. The 730 and 740 flow charts contradict each other. Both indicate that if another code is present, it must be fixed before continuing. So, they aren't too helpful. However, I did note that there is one common issue that can pertain to each and that is line pressure. With that in mind, I suggest testing line pressure to confirm it is within the manufacturer's specs. Here are the directions for doing it. The attached pictures correlate with these directions and provide specific directions and technical information.
_________________________
TEST
WARNING:
- While testing, be careful of the rotating front wheels.
- Make sure lifts, jacks, and safety stands are placed properly.
CAUTION:
- Before testing, be sure the transmission fluid is filled to the proper level.
- Warm up the engine before testing.
1. Raise the vehicle.
2. Warm up the engine, then stop the engine and connect a tachometer.
picture 1
3. Connect the oil pressure gauges to each inspection hole.
TORQUE: 18 Nm (13 ft. lbs.)
CAUTION: Connect the oil pressure gauges securely; be sure not to allow dust and other foreign particles to enter the inspection holes.
4. Start the engine, and measure the respective pressure as follows.
- Line Pressure
- 1st Clutch Pressure
- 2nd, 3rd and 4th Clutch Pressure
5. Install a new washer and the sealing bolt in the inspection hole, and tighten to the specified torque.
NOTE: Do not reuse old sealing washers; always replace washers.
Line Pressure/1st Clutch Pressure Measurement
1. Set the parking brake, and block both rear wheels securely.
2. Start the engine, and run it at 2,000 rpm.
3. Shift to [N] or [P] position, then measure line pressure.
NOTE: Higher pressure may be indicated if measurements are made in shift lever positions other than [N] or [P] position.
picture 2
picture 3
4. Shift to [D4] position, hold the engine at 2,000 rpm, and measure 1st clutch pressure.
2nd, 3rd and 4th Clutch Pressure Measurement
2. Start the engine, and run it the engine at 2,000 rpm.
3. Shift to [2] position, then measure 2nd clutch pressure.
4. Shift to [D3] position, then measure 3rd clutch pressure.
5. Shift to [D4] position, then measure 4th clutch pressure.
picture 4
picture 5
6. Shift to [R] position, then measure 4th clutch pressure.
Jan 21, 2019 at 10:18 AM
BSATTERW
I also have a 1997 Honda civic. About 3 years ago I had the same issues as the 1998 has now with the 1997 civic.
I ran the line pressure tests on it and found the average pressure range to be 80 to 90 psi. I believe it should be 110 to 120psi.
I tried to research what in the transmission would cause this issue. I found no direct answers. Seems no one is talking.
I thought maybe the pump gears or housing.
I bought a rebuild kits from OPT that included the metal discs and friction discs and all seals and o rings.
I disassembled the tranny.
Did not find the filter plugged up.
Did find a broken spring at the end of one of the spools and replaced it.
Very little sign of wear if any on pump gears and housing.
Little wear on steel discs not much on friction discs.
Did not replace torque converter.
Put it back together and re installed.
Has same issue. Checked pressures still low and in same range as before.
Swapped out each solenoid one at a time from the 1998 with no change in problem.
I went to the junk yard and bought a tranny and converter install them in the 1997 civic and had no issues since.
I have look all over the net to find out what to replace in the tranny to get the pressures back up to 110 to 120 psi range with no luck. Must be a trade secret.
Any ideas?
If I new I would try another rebuild and replace the torque converter with a rebuilt one.
In the mean time I will run the pressure tests.
I may go to the junk yard and get a tranny and converter Cost is $200.00 if I take it out myself. Add $75.00 if they remove it. How do you know if its good, their answer is Hey it was running when it crashed.
Jan 21, 2019 at 6:40 PM
  • 110,248 POSTS
Welcome back:
The transmission line pressure is controlled by a pressure regulator. The regulator valve body is located on the main valve body. The regulator valve body consists of the regulator valve, the torque converter check valve, the cooler relief valve, and the lock-up control valve. I attached a picture of the component. If there is nothing preventing pressure to be low such as dirt, a bad converter, or a bad pump, then that is my first suspect.
Note: When you checked the pump gears, did you measure clearance between them or just do a visual?
Let me know if this helps.
Jan 22, 2019 at 9:22 AM
