At low speeds transmission is shifting and banging
89,000 MILES • 2.3L • 4 CYL • AUTOMATIC
BOBBY P,
  • 5 POSTS
The transmission keeps shifting and banging at low speeds.
Apr 12, 2019 at 4:31 AM
Good afternoon,
Have you checked the transmission mount to see if it is broken?
How long since you changed the fluid and filter in the transmission?
Apr 12, 2019 at 5:38 AM
BOBBY P,
  • 5 POSTS
Yes, i put a new mount on it and have put a neutral safety switch and a transmission position sensor.
Apr 12, 2019 at 6:21 AM
BOBBY P,
  • 5 POSTS
My girlfriend left one of them FixIt things plugged in while she drove it 500 of more miles. do you think it messed up the computer?
Apr 12, 2019 at 6:24 AM
Got it.
Most likely the issue is internal in the valve body. There are accumulators that have springs inside and they break at times.
Apr 12, 2019 at 6:30 AM
BOBBY P,
  • 5 POSTS
I was thinking that might be the problem too, but i took the neutral safety switch off to make sure the neutral marks were lined up then took it for a drive and got up to speed through the gears and it shifted like it should all the way back home. i go for a drive the next day and it is back the way it was, it does not make sense to me.
Apr 12, 2019 at 6:52 AM
The neutral switch has no effect on the shifting. It is a position switch for starting and back up lights only.
No, to the FIXIT thing. I would not use that if I were you.
Apr 12, 2019 at 6:55 AM
BOBBY P,
  • 5 POSTS
Okay, thank you for your feedback, i'll see where it go's from here.
Apr 12, 2019 at 7:03 AM
You are welcome.
always glad to help.
Apr 12, 2019 at 7:04 AM
