I scanned and it says P1375 told me to replace 12 v battery.
Nov 6, 2020 at 1:09 AM
STEVE W.
✓Experienced Mechanic
It could be the battery but more common is for the fuses that get power from that battery to corrode and fail. For that you need to look at the fuses and fuse links next to the main battery. If those test okay then you can replace the battery.
Nov 6, 2020 at 1:26 AM
RISARD
MEMBER
Thanks..
Is that any issue in the lithium battery ???
Nov 6, 2020 at 1:03 PM
STEVE W.
It could be but you will want to check those fuses first.
Nov 6, 2020 at 1:18 PM
RISARD
MEMBER
Okay, thanks.
Nov 6, 2020 at 2:04 PM
RISARD
MEMBER
Hi boss, thanks for your information I fixed my error in the car. I really appreciate your help.
Nov 17, 2020 at 12:06 AM
STEVE W.
Great to hear, what did you find? bad fuse or replace the battery? Thanks for the update.
