Auto stop blinking, code P1375
12,000 MILES • 0.5L • 3 CYL • 2WD • AUTOMATIC
RISARD
  • 6 POSTS
I scanned and it says P1375 told me to replace 12 v battery.
Nov 6, 2020 at 1:09 AM
STEVE W.
  • 15,413 POSTS
It could be the battery but more common is for the fuses that get power from that battery to corrode and fail. For that you need to look at the fuses and fuse links next to the main battery. If those test okay then you can replace the battery.
Nov 6, 2020 at 1:26 AM
RISARD
  • 6 POSTS
Thanks..
Is that any issue in the lithium battery ???
Nov 6, 2020 at 1:03 PM
STEVE W.
  • 15,413 POSTS
It could be but you will want to check those fuses first.
Nov 6, 2020 at 1:18 PM
RISARD
  • 6 POSTS
Okay, thanks.
Nov 6, 2020 at 2:04 PM
RISARD
  • 6 POSTS
Hi boss, thanks for your information I fixed my error in the car. I really appreciate your help.
Nov 17, 2020 at 12:06 AM
STEVE W.
  • 15,413 POSTS
Great to hear, what did you find? bad fuse or replace the battery? Thanks for the update.
Nov 17, 2020 at 3:13 AM
RISARD
  • 6 POSTS
30 amp bad fuse and replace new one.
Nov 17, 2020 at 12:29 PM
STEVE W.
  • 15,413 POSTS
Thank you and thank you for using 2CarPros.
Nov 17, 2020 at 2:01 PM
RISARD
  • 6 POSTS
You are always welcome.
Nov 17, 2020 at 6:04 PM
