auto door lock
105,600 MILES • 3.3L • V6 • 4WD • AUTOMATIC
PCULQUI
  • 354 POSTS
Will my vehicle close the doors automatically after I remove the key from the ignition? If I leave my key in the ignition, will the vehicle give me a warning beep? I know when I press the unlock button on my remote control, if I don't open a door within 30 seconds, the vehicle will close all the doors automatically.
May 15, 2020 at 10:48 PM
Good morning,
When you remove the keys from the ignition, the doors will not lock automatically. You need to lock them with your remote. When you start the engine and start to move, the doors will lock. If you have an key for ignition, then yes, there should be a beep. If you have push button start, the remote will beep.
Apr 12, 2021 at 10:01 AM
