Auto leveling air suspension
153,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
KYLE KRAMER
  • 7 POSTS
Fully inflates one side and doesn't vent off after sitting for a week.
May 11, 2019 at 10:38 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
Quick question first. So are you saying only one side inflates? As far as venting off, the system will only vent or fill when a change in weight/ride height in the rear is detected.If only one side is working I would check for an air line leak or defective/ripped/torn leaking air bag on the non-working side. Hope this helps and thanks for using 2CarPros.
Danny-
May 11, 2019 at 11:49 AM
KYLE KRAMER
  • 7 POSTS
First time it filled three corners just fine and the right rear was all the way up and wouldn't vent. I removed the solenoid and checked the o-rings, when I put it together the right side both front and rear went all the way up and don't come down.
May 11, 2019 at 12:11 PM
KYLE KRAMER
  • 7 POSTS
Thank you for the response. I did figure it out by looking at the left front instead of the right rear and found the ride height control was unhooked.
May 11, 2019 at 8:03 PM
DANNY L
  • 5,648 POSTS
Hello again..
So is it working properly now?
Danny-
May 12, 2019 at 5:14 AM
KYLE KRAMER
  • 7 POSTS
Sorry for not getting back to you, yes it is working fine now. thank you
May 21, 2019 at 4:06 PM
DANNY L
  • 5,648 POSTS
You're welcome!
Thanks again for using 2CarPros.
Danny-
May 23, 2019 at 11:05 AM
