Does this car have the power window auto drop window down function?
1999 FORD COUGAR
260,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
WISH30
  • 124 POSTS
Does this car have this function, drop the window a little bit down when door opens? Asking because mine is not doing that so I'm curious if it is disabled or not exist at all? If don't have, is there some electronic module to add this feature? Thanks
Jul 8, 2022 at 10:44 AM
  • 110,244 POSTS
I do know what you are referring to, but this vehicle didn't come with that from the factory. As far as adding something to drop them when opened, that is something that is programmed into a vehicle's body control module. To the best of my knowledge, there isn't something you can add to it and the body control module on your vehicle won't be able to be programmed for it.
I wish I had a better answer for you. However, I don't see it being able to be done on this vehicle or any vehicle that didn't come with it. That design started with convertible tops because of leaks. It was a way to make the weather molding heavier without breaking the glass when opening and closing the door.
joe
Jul 8, 2022 at 3:05 PM
