Front two speakers no audio?
10,000 MILES • 1.4L • MANUAL
ADRIANSM
Front 2 speakers no audio but back 2 work fine.
Mar 16, 2024 at 4:45 AM
  • 55,554 POSTS
I would check the front to rear fade adjustment on the radio first. If that is okay, it sounds like the amplifier inside the radio is having a problem and is not working for the front to speakers of the system. If this is the case, I would replace the radiator with an aftermarket unit or a used stock replacement by searching Ebay. Here is how to change the unit out. Check out the images (below). Please let us know what happens.
Mar 17, 2024 at 3:00 AM
  • 55,554 POSTS
anything?
May 11, 2024 at 5:37 AM
