2005 Audi TT Question Disassembly of Driver's Door Panel
BGEATES
Electrical problem
2005 Audi TT Question 4 cyl All Wheel Drive Manual 66000. miles
Repair requires disassembly of the inside Driver's door panel to access the latch assembly for replacement. Any comments on how the remove the panel W/O defacing it in search of fasteners?
Mar 2, 2010 at 6:13 PM
DAVE H
  • 13,383 POSTS
Front door trim, removing and installing Fig. 105: Front Door Trim Remove/Install Components
https://images.2carpros.com/forum/automotive_pictures/266999_tt_2.jpg
1 - Door trim Remove screw cap - 5 - Removing screw cap Remove screw - 4 - (1x). Unclip inner and outer connecting pieces. Lift door trim about 20 cm upward and remove from door. Detach release cable for interior door handle Detaching release cable Disconnect electrical connectors
Mar 13, 2010 at 9:25 PM
