2002 Audi TT Question lights
DUNCAN TURNBULL
Electrical problem
2002 Audi TT Question 6 cyl Four Wheel Drive Manual 70k miles
My right hand haed light has stopped working.
I got a new bulb & put it in. But it still did not work. So I took the bulb out of the left hand side head light. I put the new bulb in to the left hand light socket & it worked ok the i put the old light bulb in to it aswell it worked ok. So all bulbs are fine.
I think now its must be a fuse or wireing or maybe the computer.
Can you help me on this ????
Oct 12, 2010 at 11:20 PM
DOCFIXIT
  • 18,828 POSTS
I think fuse #20 in left side dash box
Oct 13, 2010 at 7:16 AM
DUNCAN TURNBULL
Hello again thank you for your help.
I did what you said & checked 20 & 21 feuses.
I also checked all the others too.
This has not fixed the problem. Do you have anyother ideas???
thanks Duncan
Oct 14, 2010 at 8:36 PM
DOCFIXIT
  • 18,828 POSTS
Need a volt meter or test light check for voltage at headlight connector
Oct 15, 2010 at 3:47 AM
