2001 Audi TT Question Idles funky then temp drop & oil l
2001 AUDI TT
Z01TT18
Electrical problem
2001 Audi TT Question 4 cyl All Wheel Drive Manual 106k miles
When the car sits for long periods of time, and is started, it will idle high +,- 1,500rpm. After a few minutes probably<2 it returns to correct idle at just under1k. Noe here's the part that Bothers me: the temperature will rise to it's normal position, then suddenly drop when approaching high speeds +50mph. Now when the temp drops, and I come to a stop or slow, the oil light appears and those 4 wonderful and not annoying beeps are played. My car always seems to be having cooling issues... At least this time they don't seeem too threatening. Any advice?
Jan 7, 2010 at 5:24 PM
Check and test the thermostat and coolant temperature sensor and gauge switch
Jan 7, 2010 at 6:07 PM
