2001 Audi TT Question engine missing
120,000 MILES • 4 CYL • AWD • MANUAL
APRIL MORGAN
i replaced new plugs replaced with new coils replaced new o2 censors and new catylate converter what am i missing i need help
Aug 29, 2010 at 7:47 AM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Aug 29, 2010 at 7:41 PM
