2000 Audi TT Question Turn signals quit working
81,000 MILES • 4 CYL • AWD • MANUAL
CJNEPER
  • 7 POSTS
My turn signals work for a few seconds, then quit working. The emergency flashers work fine, just the turn signals quit working. where is the turn signal flasher unit located on this car?
May 5, 2010 at 5:01 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
The relay is behind the hazard light button in the center of the dash. you can hear the clicks of both the hazard lights and the signal lights coming out of that area.
To change out the relay, take out the radio, and you should have a pretty easy access to the relay switch right above the radio unit.
If the relay is not at fault then the next step would be testing the turn signal (multi function) switch.
May 5, 2010 at 12:01 PM
