2000 Audi TT Question
110,000 MILES • 4 CYL • AWD • MANUAL
RDESHONG
Transmission lost Reverse, 1st and 2nd gear. It acts as though there is nothing there. Does the transmission come apart first or does the bell housing have to be removed with the transmission to remove it from the motor to work on it. I took all the bolts out of the transmission where it is attached to the bell housing and not sure if it will come apart there without taking the bell housing bolts out of the engine.
Mar 7, 2009 at 11:46 AM
DOCFIXIT
  • 18,828 POSTS
Remove bell housing bolts pull out together
Mar 26, 2009 at 8:50 AM
