1994 Audi S4 Question struts
SUDS
Suspension problem
1994 Audi S4 Question Four Wheel Drive Manual 135000 miles
CAn you tell me if the front struts, springs and strut inserts from a 1992 Audi S2 coupe can fit an 1994 audi S4 saloon? if they can is the ride height different?
Cheers Scott!!!!!!!!
Feb 20, 2008 at 5:05 AM
VLADGEISER
  • 66 POSTS
If you are trying to lower the car after market spring kits are available every where, even at general parts stores like Advance Auto, and they are far safer as they are very specific as to how low they go.
The problem you may run into here is the S4 is a 4,300 lbs monster of a car and will probably crush the springs from the coupe.
If money is tight just chop your factory springs to the height you want.
I am not sure about the mounting plates though I would assume that you would need something more hefty for the heavier car.
Mar 1, 2009 at 5:18 PM
PHILTYACK
  • 7 POSTS
Try www.audiforums.com
Jul 19, 2010 at 6:55 PM
