2002 Audi Quattro need ERT and cost for replacing oil pan
50,000 MILES • 4 CYL • AWD • AUTOMATIC
KYOHO
doing research. who knows the ERT and cost for replacing a cracked oil pan on the audi listed above?
Oct 23, 2009 at 4:55 AM
BLUELIGHTNIN6
  • 16,542 POSTS
which Quattro is this? A4 Quattro, S4 Quattro, TT Quattro etc.. ?
Oct 23, 2009 at 5:04 AM
KYOHO
[quote:25c094d4a6="bluelightnin6"]which Quattro is this? A4 Quattro, S4 Quattro, TT Quattro etc.. ?[/quote:25c094d4a6]
Sorry,
Meant the 2002 Audi A6
Oil Pan ERT and cost
Thanks
Oct 23, 2009 at 5:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Don't believe the A6 were equipped with 4 cylinder motors as you have listed...you certain it isn't a 6 cylinder? If it is I will need to know if it is a 2.7L or a 3.0L engine and also if this is the upper or lower oil pan that is being replaced..
Oct 23, 2009 at 5:46 AM
KYOHO
sorry, doing this long distance.
2002 Audi A6
Vin#WAULD64B82N097533
6 CYLINDER 2.7L
Lower oil pan.
thanks again,
Kelly
[quote:be1b7dce0d="bluelightnin6"]Don't believe the A6 were equipped with 4 cylinder motors as you have listed...you certain it isn't a 6 cylinder? If it is I will need to know if it is a 2.7L or a 3.0L engine and also if this is the upper or lower oil pan that is being replaced..[/quote:be1b7dce0d]
Oct 23, 2009 at 7:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_1114.jpg
Oct 24, 2009 at 6:35 AM
KYOHO
thank you very much
Oct 26, 2009 at 11:13 AM
